[技术帖(电子管类)] 怎样隔山买牛
经常有的用户说手里买遍了国内人做的牛现在都怯手不敢再买国产牛了,在此本人简单说三点,一,有平直的曲线,同时还要有10k方波看振铃幅度,二,,以300b牛为例,电感量要在20h以上,漏感0-4-8-16欧的漏感分别在10mh以内同时初次级电容不要超过2nf,,第三点过流要大于300b屏流的2倍以上,买这样的牛基本有好声的保证,以上仅个人观点如有得罪人的地方请息怒!!!
第二点意见保留,其他还可以
第二点意见保留,其他还可以
EL34 发表于 2019-10-5 22:24
第二点一般很难做到,但探戈牛顶级牛确实都是如此。但这样的牛绝对有保障
可是能逹到甚至超過上面指標的牛很多
mhkcydn-sjb 在 2019-10-6 09:21 说:
我相信黄总是可以做到更
歆韵 在 2019-10-9 00:26 说:
我是說很多牛都逹到這樣的參數了,但聲音不一定就好聽
专业生产胆机变压器http://shop66931207.taobao.com
(click to enlarge)
[size=+2]Key Features:[size=+1].
  • [size=+1]"Over designed" for high fidelity, single ended, Class-A, tube output circuits (triode, tetrode or pentode tubes).
  • [size=+1]Enclosed (shielded), four slot, chassis Type "X" mounting.
  • [size=+1]Frequency response at least 20 Hz. to 20 Khz. at full rated power (+/- 1 db max., ref. 1 Khz.)
  • [size=+1]Insulated flexible leads 8" min.
  • [size=+1]For maximum versatility, all units (except the 1642SE & 1638SEA) include a 40% screen tap for Ultra-Linear, tetrode/pentode operation (if desired). The 1642SE & 1638SEA do NOT include this screen tap as they were designed principally for high impedance triode tubes.
  • [size=+1]High quality laminations, (M6) grain oriented silicon steel.
  • [size=+1]Core is gapped to reduce core saturation in Class-A tube amplifier circuits.
  • [size=+1]For general purpose or replacement use in single ended tube output circuits see our 125SE series.
Part Number
Audio
Watts
Primary
Ultra-Linear
40% Primary
Tap
Secondary
Impedance
(Ohms)
Hipot
Test
(VRMS)
Weight
(lbs.)
Impedance
(Ohms)
Max. DC
Bias
Inductance
[size=+1]1640SEA
30
1,250
200 ma.
14 HenrysYes
4-8-16
2,000
11
[size=+1]1627SEA
30
2,500
160 ma.
20 HenrysYes
4-8-16
2,000
11
[size=+1]1630SEA
303,500135 ma.42 HenrysYes4-8-162,00011
[size=+1]1628SEA
30
5,000
120 ma.
48 HenrysYes
4-8-16
2,000
11
[size=+1]1642SE
755,000300 ma.53 HenrysNo4-8-16
3,500
28
[size=+1]1629SEA
30
6,500
100 ma.
55 HenrysYes
4-8-16
2,000
11
[size=+1]1638SEA
3010,00090 ma.88 HenrysNo4-8-16
2,000
11
mhkcydn-sjb 在 2019-10-6 09:26 说:
不知测试条件但都已经20h以上了
pb2400 在 2019-10-6 11:55 说:
不知测试条件的数据,有用吗?
mhkcydn-sjb 在 2019-10-6 13:06 说:
在听不到现场声音的情况下,只能参考数据了
关注中
激情燃烧的岁月,阳光灿烂的日子,一个伟大的时代(1949—1978)
隔山买牛
无从入手
隔山吹牛
独领风骚
缘分已尽,悄然无声
国外的月亮总是比国内的圆,国内精品牛并不缺少但是装逼不够逼格再加上心理作用当然不排除淘宝的低价劣质牛在里面影响大家
吹嘘数据的时候,要明确的告诉人家你是怎么测试的。有没有适当的仪器,很多二手仪器的精度是没保障的。
电感的测试,必须要知道测试频率,测试电平,单端牛有没有加偏置,加了多大的直流偏置,否则光秃秃的电感量,根本没有任何的价值!
其他的参数也一样,分布电容怎么测试的?是大家都认可的方式?漏感也是一样。
老曹说的有道理,不同搭配效果完全不同
